AW-XM458 蓝牙功能查找不到
AW-XM458 蓝牙功能查找不到
胡巴
Hi,我现在正在使用AW-XM458,在我调试的过程中,或者使用的过程中,蓝牙功能就使用不了。我的SOC上也找不到此设备了,如果我想恢复蓝牙功能的使用,就得重新刷镜像。
我排除了镜像的问题,原因是我用了一个没问题的镜像,交叉测试了,最后定位出是模组本身的问题。
请帮我解答一下,谢谢!
胡巴
我用的soc是RK3588,系统是ubuntu 22.04,这个问题我现在复现方法是,整机开关机80几次,就会出现蓝牙模组通讯超时。
shaun_wu
Hello @胡巴
你可以参考UM11490 chapter5 Bluetooth debugging抓取蓝牙的log给我们,我们看一下
shaun_wu
hello @胡巴
你用的什么平台?可以分享复现问题的操作和日志么?
%3CLINGO-SUB%20id%3D%22lingo-sub-2176978%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EAW-XM458%20Bluetooth%20function%20cannot%20be%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176978%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I'm%20using%20the%20AW-XM458%20right%20now%2C%20and%20during%20my%20debugging%20process%2C%20or%20while%20I'm%20using%20it%2C%20the%20bluetooth%20function%20won't%20work.%20I%20can't%20find%20this%20device%20on%20my%20SOC%20anymore%20either%2C%20so%20if%20I%20want%20to%20restore%20the%20use%20of%20the%20Bluetooth%20function%2C%20I%20have%20to%20re-flash%20the%20image.%3C%2FP%3E%3CP%3EThe%20reason%20I%20ruled%20out%20a%20mirror%20issue%20is%20that%20I%20used%20a%20mirror%20that%20was%20fine%2C%20cross-tested%20it%2C%20and%20finally%20pinpointed%20it%20as%20a%20problem%20with%20the%20module%20itself.%3C%2FP%3E%3CP%3EPlease%20help%20me%20out%2C%20thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193055%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20AW-XM458%20%E8%93%9D%E7%89%99%E5%8A%9F%E8%83%BD%E6%9F%A5%E6%89%BE%E4%B8%8D%E5%88%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193055%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255305%22%20target%3D%22_blank%22%3E%40Whoopa%3C%2FA%3E%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYou%20can%20refer%20to%20UM11490%20chapter5%20Bluetooth%20debugging%20to%20grab%20the%20bluetooth%20logs%20for%20us%2C%20let's%20see%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188556%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20AW-XM458%20%E8%93%9D%E7%89%99%E5%8A%9F%E8%83%BD%E6%9F%A5%E6%89%BE%E4%B8%8D%E5%88%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188556%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20soc%20I'm%20using%20is%20RK3588%20and%20the%20system%20is%20ubuntu%2022.04%2C%20the%20way%20I'm%20reproducing%20this%20problem%20is%20that%20the%20whole%20machine%20switches%20on%20and%20off%2080%20times%20and%20then%20the%20bluetooth%20module%20communication%20times%20out.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177837%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW-XM458%20%E8%93%9D%E7%89%99%E5%8A%9F%E8%83%BD%E6%9F%A5%E6%89%BE%E4%B8%8D%E5%88%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177837%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255305%22%20target%3D%22_blank%22%3E%40hubba%3C%2FA%3E%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWhat%20platform%20are%20you%20using%3F%20Can%20you%20share%20the%20actions%20and%20logs%20to%20reproduce%20the%20problem%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
