88W9098(WLAN:SDIO) loading driver with mmc error message
Andy_Hsieh
Hi Support,
We encountered an issue while testing 88W9098(WLAN:SDIO) on openwrt 22.03.3 with kernel 5.10.161.
While loading driver, the mmc error message appeared and there's no wireless interface at all.
Using below commands to load driver.
# insmod mlan.ko
# insmod moal.ko drv_mode=7 cal_data_cfg=none fw_name=nxp/sdiouart9098_combo_v1.bin
Could you please help guide how to load driver with correct commands and suitable parameters?
What could be the reason for showing mmc related error message?
Please advise.
ocourson
Dear @Andy_Hsieh
I just sent you a private message, as we need you to share private information to continue investigations.
Olivier
Andy_Hsieh
Hi Olivier,
I don't receive your private message. Please check once.
Thanks.
ocourson
Dear Andy,
Could you please clarify your setup ?
- host used
- 88W9098 module used
- how you connect 88W9098 to your host
Olivier
