Hi Guys
I'm using Processor Expert 10.4 to configure a Vybrid
Problem I have is that when I select pin B14 for I2C0 SCL, the tool also checks pins K18 and L3 (which I need for other things) -see attachment
i2C1 behaves as I would expect (I can select any one of the available pins)
Is this a bug in the tool, or is there some strange dependency in the chip I'm not aware of ?
