Dear Sir/Madam,
We plan to use the Automotive Vybrid processors in automotive projects. But in the datasheet, operating temperature is shown between -40 to 85 degree celcius.
As far as I know, operating temperature of Automotive components should be at least 105 degree celcius. Do you know the R series of Vybrid's temperature value will be updated?
Best regards.
Mehmet Ali İpin
Solved! Go to Solution.
Hi Mehmet,
this is marketing decision. You can contact your FAE distributor for more information.
Vilem
Dear Vilem,
Thank you. I will ask our FAE.
Best regards.
Vilem is correct, those decisions are made by our marketing team and your FAE should be able to give you that info faster. Let us know of any other question you may have.
