Vybrid VF6 with secure module
4,856件の閲覧回数
fernandoalcaide
Dear,
I want to use your  Vybrid VF6 with secure module, I need to know the size of:
SNVS_LP
SNVS_HP
memory zeroize
Can you help me?
Thank you in advance.
4,596件の閲覧回数
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
9 返答(返信)
4,597件の閲覧回数
CommunityBot
Community Manager
NXP Community!
4,598件の閲覧回数
rendy
please check "14.9.6 Secure memory" of the Vybrid Secure Reference Manual.
Generally secure memory is divided into pages and pages are assigned to partitions. Partitions could have CSP bit set. All pages assigned to the partition with CSP bit set are zeroized when security is violated (or when POR occured).
Rene
4,598件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
rendy​ can you  check and share your comments?
4,598件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ please continue with the follow up.
4,598件の閲覧回数
timesyssupport
Senior Contributor II
Hi Karina,
I searched the relevant sections in the VYBRIDSRM pdf, but could not find the information about the size of these modules. Can the NXP Vybrid team comment here?
Timesys Support
4,598件の閲覧回数
fernandoalcaide
Zeroize memory: this memory is reset  in the case there will be active one input anti-tamper.
4,599件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
fernandoalcaide​ did you get previous update?
4,599件の閲覧回数
timesyssupport
Hi Fernando,
Can you clarify what you mean by the size of memory zeroize? Other than the SNVS registers at base address 0x400A_7000, I could not find any other information about the size of these modules in the VYBRIDSRM pdf. Can the NXP Vybrid team comment here with further information?
Timesys Support
4,599件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help here?
