Hi community.
I confirmed Vybrid VF522R VADCSE0 pin input impedance is 75 ohms .
so, I want proof of impedance image diagram.
Solved! Go to Solution.
Hi Takashi,
The pins as you mentioned VADC inputs at AFE are defined as Composite video inputs so characteristic impedance is 75Ohm.
But unfortunately there is not a sherable schematic that shows the internal structure of the pin.
Alejandro
