Dear Soichi,
It is a bit difficult to answer the request kind of "blindly", i.e. without knowing all the application details, why specific questions pop up, etc., therefore not really focusing on what would the best for the customer - may you provide such details, please?
Regarding your last questions:
Regards, Naoum Gitnik.
Dear Soichi,
This output signal is used to control the external transistor (see the 'External NPN Ballast' section in the Datasheet), which is a part of the linear voltage regulator powering the core (1.2V) in the major operating modes, including the RUN one used practically in every Use Case.
Dear Naoum,
Thank you for a reply.
Is BCTRL a pin controlled by Power Management mode?
Please give me information more detailed than one of control.
If there are application notebooks, I want it.
Soichi
Dear Soichi,
