Hi, Dose VDDA33_AFE, VDD12_AFE use for Video ADC? I not use Video ADC. For reasons of it, do I not need to use VDDA33_AFE, VDD12_AFE? Best regards, soichi yamamoto
Solved! Go to Solution.
Hello Soichi-san,
After reviewing the datasheet for the VF6xx, it appears that VDDA33_AFE and VDD12_AFE are only used for Video ADC, so you should not need to use these if you are not using Video ADC.
Timesys Support
timesyssupport are you available to help on this case?
Hello Soichi-san,
Timesys Support
