VF5xx : A register cannot set only FB_CSAR4,FB_CSMR4,FB_CSCR4.
已解决
跳至解决方案
1,946 次查看
soichiyamamoto
Contributor V
Hi This is an urgent request. I use CS5. A register cannot set only FB_CSAR4,FB_CSMR4,FB_CSCR4. ※I set a value to a register, but am readable with all 0. The debugger that I use it is DS5. A register can set the follows. FB_CSAR0 FB_CSMR0 FB_CSCR0 FB_CSAR1 FB_CSMR1 FB_CSCR1 FB_CSAR2 FB_CSMR2 FB_CSCR2 FB_CSAR3 FB_CSMR3 FB_CSCR3 Please tell me how to deal with this problem. Best Regards, soichi yamamoto
标签 (1)
1 解答
1,677 次查看
naoumgitnik
Senior Contributor V
Dear Soichi,
As per the latest information form the Design team, we do not support CS corresponding to FB_CSCR4 - only have four CSs in Vybrid.
We will have to fix the documentation.
Regards, Naoum Gitnik.
在原帖中查看解决方案
7 回复数
1,677 次查看
timesyssupport
Senior Contributor II
As per the chip configuration (Chapter 8 - Table 8-13. FlexBus Multiplexing) and signal multiplexing (Chapter 4 - Table 4.1 Pinouts) sections in the Vybrid reference Manual , FB_CS4_b signal is not listed for Vybrid Chip.
karinavalencia - The behaviour of writing to FB_CSAR4, FB_CSMR4, FB_CSCR4 registers is not documented in the reference manual, could you please ask one of the Freescale Applications Engineers to confirm the same.
Timesys Support
1,677 次查看
soichiyamamoto
Contributor V
Hi, I get comment from you in the following thread. https://community.freescale.com/thread/312766 What is right? Be quick! We haven't much time. Best regards, soichi
1,678 次查看
naoumgitnik
Dear Soichi,
1,677 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
naoumgitnik do you have an update on this case?
1,677 次查看
soichiyamamoto
Contributor V
Hi, I was able to obtain a reply from Local FAE. Thank you for support. soichi,
1,677 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
naoumgitnik can  you check and confirm previous comment  from Timesys?
1,677 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you help on this case?
