Table 79. Revision History in Data Sheet Rev. 7
soichiyamamoto
My customer have about "Table 79. Revision History (continued) " in "VF6xx, VF5xx, VF3xx Data Sheet, Rev. 7, 04/2014".
It is the following part.
 ”In the 24MHz external oscillator electrical characteristics table, revised the min value of VIH and max value of VIL”
Q1)This version up reason?
Q2)The reason why Rev 6 was not disclosed in Jan 2014?
soichi
naoumgitnik
Senior Contributor V
Dear Soichi,
  • The reason the ”In the 24MHz external oscillator electrical characteristics table, revised the min value of VIH and max value of VIL” change was that these parameters were mentioned in several places of the older document, and practically the same values were presented in the inconsistent, somewhat confusing form, so we fixed that.
  • RossMcLuckie, correct me if I am wrong, but my understanding is that Rev 6 was for review by the team only and to be converted into Rev 7 upon approval.
Regards, Naoum Gitnik.
soichiyamamoto
Dear Naoum,
The reason mentioned above approved it.
Please tell me the technical reason why a value was revised.(VIH:0.75→0.8 VIL:0.25→0.2)
soichi
soichiyamamoto
Dear Naoum,
Thank you for reply.
May I ask why the reason why we switched from revision 5 directly to 7, having skipped 6, is so critical, please? (Ross McLuckie<https://community.freescale.com/people/RossMcLuckie>)
My customer designs the data sheet to a base. It performs mass production soon.
They may have to change a design. Mass production will be late if so.
data sheets rev.6 are changed very much.
They will need the information if they update data sheet.
Why were Rev6 not made open?
My and my customer wants to know the reason that information disclosure delayed to Rev.7.
soichi
RossMcLuckie
There was no official rev 6, the docs team assumed there was a rev 6 since the review draft was open so long, I highlighted this to them, but as they had already produced the release version 7 the decision was taken just to publish it and skip 6 and not delay the release any more.
Ross
soichiyamamoto
Dear Ross,
I received your message.
Thank you.
Please tell me if there is any information about that.
soichi
RossMcLuckie
As explained by Naoum, there were a few different places the spec was quoted and slight differences in the values used, 0.2 or 0.25, 0.75 or 0.8, we have standardised on 0.2 and 0.8, aligns with iMX, which is where the oscillator came from and more characterisation work was carried out.
Ross
soichiyamamoto
Dear Ross,
What does the data sheet show concretely?
Soichi
RossMcLuckie
0.2 and 0.8 is the spec we support and should be what is displayed in all places referring to this spec.
soichiyamamoto
Dear Ross,
This Thread is close.
soichi
