Software Difference
Software Difference
1,510 次查看
keisukewatanabe
Dear support,
Is/are there difference(s) between the (Freescale Provided) basic software libraries of VF5 and VF6?
The point of this question is that we are developing our software based on the VF6 evaluation board,
and we are anxious if the software can work on our final target board which will be build on VF5.
Keisuke
标签 (3)
1,318 次查看
Jmart
Keisuke,
The main difference between the VF5 and VF6 Vybrid silicon is the addition of the Cortex-M4 core to the VF6. As long as your software does not utilize the Cortex-M4, you can expect your application code to run the same when you move to your target hardware.
All the best.
1,319 次查看
Jmart
Keisuke,
All the best.
