NAND flash read performance?
2,160 次查看
zoltanjanosy
Does anyone have any figures for the read performance of the NAND flash controller, when used with 32 bit error correction? I am interested in the added latency of the error correction, including any software overhead (in plain English, how much does it take to do the error correction on a block of memory).
Zoltan
标签 (5)
标记 (3)
1,717 次查看
timesyssupport
Senior Contributor II
Hello Zoltan,
On the Vybrid Tower module, we have not yet collected NAND performance statistics, with/without ECC. We only have Rev. E hardware on hand at this moment, our Rev. G is currently unavailable for testing purposes. Once it returns, we can put together some test figures as they apply to the VF6xx Tower module.
Timesys Support
1,717 次查看
billpringlemeir
Contributor V
See: VF6xxx NFC (NAND) module clocking, where I give some numbers and code to improve it.
1,718 次查看
timesyssupport
Hello Zoltan,
Timesys Support
1,717 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport are you available to  help on this case?
