Is END_CFG (byte swapper) implemented in the QSPI peripheral?
1,442 次查看
beat
It looks like writing to this register is not having an effect (in neither normal nor disabled mode).
Thanks to anyone who knows.
标记 (3)
1,238 次查看
naoumgitnik
Senior Contributor V
Dear Russ,
May you refer me to a place in the Vybrid documentation where this feature is mentioned, please?
Sincerely, Naoum Gitnik.
1,238 次查看
beat
30.32.1 Module Configuration Register (QuadSPIx_MCR)
Figure 30-417. QuadSPI memory map
VYBRIDRM v. 5
As for my application, I just implemented byte swapping manually, which is probably better anyway.
Thanks, Naoum
1,238 次查看
naoumgitnik
Dear Russ,
Sorry for delay...
- If you still consider this issue important for you, may you be more specific, please? - Provide your settings (codes) which did work and did not work; we will review them, possibly with the IC design team.
- If not, we may leave it in the current state.
