How to use both sdhc0 and sdhc1?
1,688件の閲覧回数
jarodnan
I'm developing a custom board base on the VF610 tower board. I'm planning to use the sdhc0 with an eMMC (MTFC4GLDDQ-4M IT ) with 8 bit data lines as the boot media, and sdhc1 as an external SD storage. What modifications should I make to the u-boot and linux kernel source code?
And it is possible to use an SD card to boot a newly made boar to make the onboard eMMC bootable? Just set BOOT_CFG to SD boot?
ラベル(2)
2 返答(返信)
1,423件の閲覧回数
timesyssupport
Senior Contributor II
Custom hardware leveraging boot methods in this fashion are beyond what we are able to support in the general forums. Please contact sales@timesys.com for dedicated engineering services to assist you.
Thank you,
Timesys Support
1,423件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help with this case?
