Mike,
What hardware are you using, your own or the TWR?
Have you looked for any activity on the hardware pins to see if the processor is even trying to access the device?
You might want to re-chack your setting on CF4, you seem to be set bit 6, which has no relevance, my assumption you are trying to use CS2, this would be bit 5.
Other settings suggest SPI0, 24-bit addressing.
If selection of CS2 is not the problem here, please confirm your hardware configuration, that you have seleceted all the correct IOMUX pins as detailed in the RM and whether you see any activity on any of the SPI0 pins as you try to boot.
Ross
