Eclipse IDE support on linux platform for phyCORE-Vybrid RDK Board
2,463 次查看
swapnilv
I am using Phytec's phyCORE-Vybrid Rapid Development Kit Board which has Vybrid processor.
The Linux BSP for this board is provided by timesys.
I would like to know if I can use Eclipse IDE for development and debugging purpose on linux platform for this board.
Swapnil
2,283 次查看
timesyssupport
Senior Contributor II
Hello Swapnil,
Yes, you can use Eclipse IDE for development and debugging. Note, we are not able to support Eclipse issues as we do not maintain/produce the IDE.
DS-5 is also an alternative IDE you may use, but, does require a license for complete functionality.
Timesys Support
6 回复数
2,284 次查看
timesyssupport
Hello Swapnil,
Timesys Support
2,283 次查看
swapnilv
Thanks for the information..
Do you know any known major issues when using Eclipse IDE with Vybrid processor on linux platform.
Kindly let me know.
Swapnil
2,283 次查看
timesyssupport
None that I am aware of - though I believe only DS-5 is capable of interfacing with both the A5 and M4 cores.
Timesys Support
2,283 次查看
swapnilv
Thanks for your valuable inputs.
Swapnil
2,283 次查看
swapnilv
Waiting for a reply...
Swapnil
2,283 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help to review this case?
