Does somebody know the stable toolchain, when the booting continues to function both over the SD card and over TFTP after rebuilding of the 3.13 kernel?
lyudmilavoronin
Hello
We have Linux kernel 3.13 from Timesys for TWR-VF65GS10.
I built Linux kernel 3.13 with different versions of toolchain on webfactory and
all the time I receive different results.
There were such results:
1. Booting over SD card functions with original uImage  but after rebuilding uImage does not function.
   Booting over TFTP continues to function after rebuilding uImage.
2. Booting over SD card continues to function after rebuilding uImage, but booting over TFTP does not function.
I will not list all received results as there is a lot of them, but I did not receive result when after rebuilding of the kernel everything functioned
What's the problem?
thanks
Labels (3)
lyudmilavoronin
Additional information.
I build kernel via timesys toolchain, via webbuild SDK.
Does somebody use timesys toolchain from webbuild SDK?
thanks.
jamesbone
timesyssupport‌, Can you please help ?
