Does VF61 CPU have hardware Floating Point and if so, how to use it in Timesys Linux ?
1,555件の閲覧回数
dragan
Respected Colleagues,
does VF61 CPU have hardware Floating Point and if so, how to use it in Timesys Linux ?
Thanks in advance.
With best regards,
Dragan Kujovic
ラベル(3)
1,330件の閲覧回数
timesyssupport
Senior Contributor II
Hello Dragan,
You can enable hardware FP with Timesys Desktop Factory. In your top-level Factory directory, run 'make menuconfig'. Navigate to 'Toolchain Configuration > GCC', and enable 'Enable ARM hard-float support'. Save and exit Factory menuconfig, and run 'make clean && make' to rebuild.
Timesys Support
4 返答(返信)
1,331件の閲覧回数
timesyssupport
Hello Dragan,
Timesys Support
1,330件の閲覧回数
alejandrolozan1
That is very helpful. Thanks.
Alejandro
1,330件の閲覧回数
dragan
Thanks for your answer.
Yes, now hardware floating point work.
With best regards,
Dragan Kujovic
1,330件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you help here?
