Respected Colleagues,
does VF61 CPU have hardware Floating Point and if so, how to use it in Timesys Linux ?
Thanks in advance.
With best regards,
Dragan Kujovic
Solved! Go to Solution.
Hello Dragan,
You can enable hardware FP with Timesys Desktop Factory. In your top-level Factory directory, run 'make menuconfig'. Navigate to 'Toolchain Configuration > GCC', and enable 'Enable ARM hard-float support'. Save and exit Factory menuconfig, and run 'make clean && make' to rebuild.
Timesys Support
Hello Dragan,
Timesys Support
That is very helpful. Thanks.
Alejandro
Thanks for your answer.
Yes, now hardware floating point work.
With best regards,
Dragan Kujovic
timesyssupport can you help here?
