Changing size and number of receive buffers in MCC on Cosmic Vybrid board
1,727件の閲覧回数
gurdeepakjoshi
We have identified mcc_config.h and modified it to change the size and
number of receive buffers in mcc and compiled as instructed in mcc
documentation. But its not working on Cortex A5(Linux) and M4(Mqx).
Can you please send us a step by step guide for compiling and building
these changes on both M4(mqx) and A5(linux).
ラベル(2)
1,409件の閲覧回数
timesyssupport
Senior Contributor II
Hello Gurdeepak,
To rebuild MCC in MQX source, clean and rebuild the MCC project, and any other MQX application projects that use the MCC project.
To rebuild MCC for Linux using Desktop Factory, be sure that your modifications are in place at the MCC build directory, located in your top-level Factory directory: build_armv7l-timesys-linux-gnueabi/mcc-kmod-1.06/mcc-kmod-1.06/. To rebuild the mcc-kmod project, you can issue the following command from your top-level Factory directory:
# make mcc-kmod-restage && make
Redeploy the resulting kernel and RFS images generated by the Factory build, under build_armv7l-timesys-linux-gnueabi/images/.
Thanks, and let me know if you have any questions.
Timesys Support
1,409件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you  help to  attend this case?
