Hi community.
Desclibe on Vybrid Reference Manual, Rev.5 of 55.2.2 Features below.
・Blending of each pixel using up to 6 source layers dependent on size of panel
Question1
Does this sense would up 6 Layers that it can be blending simultaneously.
Or simultaneous blending Will to 6 pixels.
If 6 pixels.
Question2
What is six upper limit of the overlap of the frame buffer.
And ,In the same coordinates on the transparency (alpha value fully transparent), NOCOUNT is pixel.
已解决! 转到解答。
I am not sure if I understand correctly the question. But you can blend up to 6 layers. And every pixel that overlaps to other will be taken care of.
Here you can find a training that explains the DCU module. In concept it applies to vybrid.
http://www.freescale.com/files/training/doc/dwf/DWF13_APF_AUT_T0500.pdf
I hope that helps.
/Alejandro
I hope that helps.
/Alejandro
