A gem from the MQX TWR-VF65GS10_a5 BSP
Search instead for
Following is a gem from the MQX TWR-VF65GS10_a5 BSP (ver. 4.1.2). I am unsure whether this has been fixed in later versions, but on the off chance it is still there:
    // clock
    CCM_CSCMR2 &= ~CCM_CSCMR2_RMII_CLK_SEL_MASK;
    CCM_CSCMR2 |= 0 << CCM_CSCMR2_RMII_CLK_SEL_SHIFT;  // RMII_CLK // <------
    CCM_CSCDR1 |= CCM_CSCDR1_RMII_CLK_EN_MASK;      // enable RMII_CLK_EN
The extract is from where the IOMUX is set for the ENET/RMII (init_gpio.c::_bsp_enet_io_init).
Cheers.
Labels (3)
