Chinese words display garbled in MCUXpress terminal
2,796件の閲覧回数
Yuffie
When I tested the Chinese model of VIT, I found that the the display of MCUXpress terminal was garbled.
Then I switched to using tera as the com port to output but got the same result. Weirdly, I used Keil IDE to output Chinese in tera and it is normal, only MCUXpress could not print out Chinese.
Did anybody meet the same problem? How can I solve it?
0 返答(返信)
