This demo contains several error UVP_S12_DEMO
1,350件の閲覧回数
aliastroboy
hi
I bought a platform with a APS12C128 Module .. and when I tried to run an application with demonstration: UVP_S12_DEMO ie when I compile it generates a lot of errors
Please help me
thank you
Original Attachment has been moved to: UVP_S12_DEMO.zip
1,182件の閲覧回数
admin
Specialist II
You need to edit the device_headers.h file to uncomment the APS12C128 bit and comment out the APS12D
#include <mc9s12c128.h>
#pragma LINK_INFO DERIVATIVE "mc9s12c128"
#define HCS12D 0
#include "AP_s12c128slk.h"   /* I/O definitions and init routines */
#include "PB_s12c128slk.h"   /* I/O definitions and init routines */
//Uncomment the lines below for using the HCS12DT256
// #pragma LINK_INFO DERIVATIVE "mc9s12dt256"
// #include <mc9s12dt256.h>
// #define HCS12D 1
// #include "AP_s12dt256slk.h"   /* I/O definitions and init routines */
// #include "PB_s12dt256slk.h"   /* I/O definitions and init routines */
//#include "PB_s12dt256slk.h"   /* I/O definitions and init routines */
You will get a lot of "Warnings"(doesn't effect code compile) but you should not get any "errors" (stops code compile) when things are configured proper.
