How to measure power of different modules of the smart car?
2,169 次查看
AnuragSharma
I need the information about the power consumption of the different components of the smart car. Can anyone help?
标记 (1)
4 回复数
2,032 次查看
AnuragSharma
to know about the power :P jokes apart, to calculate the battery backup.
2,032 次查看
shri
why do you measure power
2,032 次查看
AnuragSharma
Thanx a lot, John! You've saved me from a potential horror. :)
2,032 次查看
admin
Specialist II
Most of the chips have "idle" and "max" power specifications.  (see the respective datasheet to find it).  A board generally doesn't spec power consumption.  At any rate, it's pretty easy to measure.  Run your code, put a current meter inline with the thing you want to measure and you'll get your current measurement.  Then do a little math to get Power..
