Guys i'm facing some problem while using a driver IC UBA1313t and to resolve those problem i need a data sheet of this IC UBA1313t Kindly send me the data sheet if someone have it asap.
4,711 次查看
asadrehman
the manufacturer of this IC is philips. i did alot of search but can't able to find the datasheet of IC UBA1313t
1,445 次查看
Andrey_Bastyl
Hello! Have you received a datasheet about this chip? if so, could you share it with me? Thank you.
