The new TFC-KIT featuring the Freedom board FRDM-KL25Z board with Motor Control shield is now available via the Freescale site for purchase. As you sign up for the Freescale Cup and acquire your new intelligent car kit, you will experience a new level of integration with the technology delivered with it. The kit is MBED enabled, allowing you to use simpler programming interface to build and program your car.
If your choice is to use a Tower module, a TRAK board or other Freescale MCU boards to use on your Freescale Cup intelligent car, you can still use the Freedom board for many other applications.
More information about the Kit can be found on our Knowledge Center
The TFC-KIT can be purchased via our Direct Buy system
Solved! Go to Solution.
