For the needs of a project, we want to use 2 wheel encoders on our car. I would like to know if there is a way to connect the ROB-12629 wheel encoders (referenced in the list of additional components) to the RDDRONE-FMUK66 and how to read the encoder data inside the PX4 firmware?
Hardware configuration:
chassis: DFRobot ROB0165 brushless
platform: RDDRONE-FMUK66
camera: Pixy2Cam
Thank you,
Alexandre
Hey Alexandre,
You can connect the encoders to the PWM outputs in the back of the FMU. The PWM pins should be bidirectional. For programming see the PWM input example at the PX4 master: Firmware/src/drivers/pwm_input at master · PX4/Firmware · GitHub
Katrin
