I have received a question from team Spektrum that is worth clarifying on the forum: what is the equipment that will be made available during the finals for working on the cars.
The ESIEE is giving you access to their technical lab on demand. This means that they do have some soldering equipment there. There is not space for everybody so teams will get limited time if they need to use it.
We will provide multi-plugs for you to connect your battery chargers, laptops and other equipment you might bring. Each team will have a space to do work in the vicinity of the track.
I will bring along a few more battery chargers and some space car chassis in case there is some breakage.
Solved! Go to Solution.
