Hands-On Workshop: Secure Connection to Google Cloud IoT Core
Search instead for
In this session you will learn how the A71CH Security IC can be used to establish a secure connection between an IoT device and Google Cloud IoT Core. This connection is established using an MQTT Bridge running across Transport Layer Security protocol (TLS). The same procedure could be applied to connect to AWS services, OEM Cloud, etc. maintaining the credentials secured.
Version history
Revision #:
1 of 1
Last update:
‎10-31-2018 12:35 PM
Updated by:
