Taplinx iOS appcrash on tag response
4,854件の閲覧回数
DamianD
Hi, i followed UG10045.pdf and created ios application. I created ApduExchangeWithByteArray method and implemented its contents. However when send back response from tag back to taplinx library, application crashes with following entries from device log:
Time	Device Name	Type	PID	Tag	Message
Nov  6 20:44:31	iPhone	Notice	5223	MobileFacilityApp	Command Set - 1
Nov  6 20:44:31	iPhone	Notice	5223	MobileFacilityApp	Command Set - Native
Nov  6 20:44:31	iPhone	Error	0	kernel(Sandbox)	Sandbox: MobileFacilityApp(5223) deny(1) sysctl-read kern.bootargs
Nov  6 20:44:38	iPhone	Notice	5223	MobileFacilityApp(UIKitCore)	Received memory warning.
Nov  6 20:44:40	iPhone	Notice	0	kernel	EXC_RESOURCE -> MobileFacilityApp[5223] exceeded mem limit: InactiveHard 3072 MB (fatal)
Nov  6 20:44:40	iPhone	Notice	0	kernel	memorystatus: killing process 5223 [MobileFacilityApp] in high band FOREGROUND (100) - memorystatus_available_pages: 44859
When i sent back empty response back to taplinx library (just TL_TagAPDUResponse without setting ResponseData) - app does not crash and i get error about incomplete response (which is expected). What am i doing wrong?
4,813件の閲覧回数
DamianD
apparently included headers in TapLinx-v2.0.0 are all wrong. In TapLinxApduHandler.h we see declaration:
- (nullable TL_TagAPDUResponse *)apduExchangeWithByteArray:(NSData *_Nonnull)apduData;
but in reality we should return IOSByteArray*, otherwise app will crash with aforementioned symptoms
6 返答(返信)
4,755件の閲覧回数
ukcas
Hello Damian,
Maybe the cause of the error is some exceeding memory limit and not TapLinx library?
The application which integrates TapLinx Library can be used as following (no need for ApduExchange implementation on top)
Set the delegate to the APDUHandler
let reader = TL_IOSNFCReader(uid: tag.identifier, historicalBytes: tag.historicalBytes ?? Data())
handler = TapLinxApduHandler(reader: reader)
handler.delegate = self
libraryManager?.setApduHandlerWithApduHandler(handler)
Next Step will be to implement the protocol method inside the application
func apduExchange(withByteArray apduData: Data) -> TL_TagAPDUResponse? {
        var tagAPDUResponse: TL_TagAPDUResponse?
        if connectedTag != nil {
            // Send Tag Type Native of ISO and the apdu as NFCISO7816APDU
            executeAPDUCommandOn7816Tag(tagType: tagtype, apdu: apdu) { data in
                let appendedData = data
                tagAPDUResponse = TL_TagAPDUResponse(responseData: appendedData, tag: self.currentTag)
                semaphore.signal()
            let _ = semaphore.wait(timeout: .now() + 3.0)
        } else if connectedMifareTag != nil {
            let semaphore = DispatchSemaphore(value: 0)
            print("MIFARE CAPDU -> \(apduData.hex)")
            executeAPDUCommandOnMIFARETag(apdu: apduData) { data in
                print("RAPDU <- Data: \(data.hex)")
                tagAPDUResponse = TL_TagAPDUResponse(responseData: data, tag: self.currentTag)
                semaphore.signal()
        print("Tag Response \(String(describing: tagAPDUResponse))")
        return tagAPDUResponse
Hope this simplification would help you.
TapLinx team
4,752件の閲覧回数
DamianD
@ukcas - what version of taplinx ios library is 'current'? Because i have 2.0.0 and it definitely crashes when i return TL_TagAPDUResponse from apduExchange method, it has to be raw IOSByteArray from j2objc library. I'm using c# bindings for taplinx library, but it does not matter in this problem.
4,753件の閲覧回数
DamianD
hi
the crash definietly comes from taplinx library because when i changed
to actually:
- (nullable IOSByteArray*)apduExchangeWithByteArray:(IOSByteArray*_Nonnull)apduData;
It started working
4,745件の閲覧回数
DamianD
followup - when i changed my implementation to use provided TapLinxApduHandler instead of providing my own - then apduExchangeWithByteArray does conform to contract - (nullable TL_TagAPDUResponse *)apduExchangeWithByteArray:(NSData *_Nonnull)apduData;
4,810件の閲覧回数
DamianD
one more thing - apduData is really also IOSByteArray, not NSData
4,814件の閲覧回数
DamianD
%3CLINGO-SUB%20id%3D%22lingo-sub-1989340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%BF%E3%82%B0%E3%83%AC%E3%82%B9%E3%83%9D%E3%83%B3%E3%82%B9%E3%81%A7%E3%81%AETaplinx%20iOS%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%20%3CSPAN%3EUG10045.pdf%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6iOS%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AFApduExchangeWithByteArray%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%BF%E3%82%B0%E3%81%8B%E3%82%89taplinx%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E5%BF%9C%E7%AD%94%E3%82%92%E8%BF%94%E3%81%99%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-csharp%22%3E%3CCODE%20translate%3D%22no%22%3ETime%09Device%20Name%09Type%09PID%09Tag%09Message%0ANov%20%206%2020%3A44%3A31%09iPhone%09Notice%095223%09MobileFacilityApp%09Command%20Set%20-%201%0ANov%20%206%2020%3A44%3A31%09iPhone%09Notice%095223%09MobileFacilityApp%09Command%20Set%20-%20Native%0ANov%20%206%2020%3A44%3A31%09iPhone%09Error%090%09kernel(Sandbox)%09Sandbox%3A%20MobileFacilityApp(5223)%20deny(1)%20sysctl-read%20kern.bootargs%0ANov%20%206%2020%3A44%3A38%09iPhone%09Notice%095223%09MobileFacilityApp(UIKitCore)%09Received%20memory%20warning.%0ANov%20%206%2020%3A44%3A38%09iPhone%09Notice%095223%09MobileFacilityApp(UIKitCore)%09Received%20memory%20warning.%0ANov%20%206%2020%3A44%3A40%09iPhone%09Notice%090%09kernel%09EXC_RESOURCE%20-%26gt%3B%20MobileFacilityApp%5B5223%5D%20exceeded%20mem%20limit%3A%20InactiveHard%203072%20MB%20(fatal)%0ANov%20%206%2020%3A44%3A40%09iPhone%09Notice%090%09kernel%09memorystatus%3A%20killing%20process%205223%20%5BMobileFacilityApp%5D%20in%20high%20band%20FOREGROUND%20(100)%20-%20memorystatus_available_pages%3A%2044859%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A9%BA%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%92taplinx%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E9%80%81%E3%82%8A%E8%BF%94%E3%81%99%E3%81%A8(ResponseData%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%9B%E3%81%9A%E3%81%ABTL_TagAPDUResponse)%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%9B%E3%81%9A%E3%80%81%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%BF%9C%E7%AD%94%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99(%E3%81%93%E3%82%8C%E3%81%AF%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%82%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AETaplinx%20iOS%E3%81%AEappcrash%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%82%A2%E3%83%83%E3%83%97%20-%20%E7%A7%81%E3%81%8C%E8%87%AA%E5%88%86%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9FTapLinxApduHandler%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9F%E8%A3%85%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%20-%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81apduExchangeWithByteArray%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%A9%E3%82%AF%E3%83%88%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%BE%E3%81%99%20-%20(null%E8%A8%B1%E5%AE%B9%20TL_TagAPDUResponse%20*)apduExchangeWithByteArray%3A(NSData%20*_Nonnull)apduData%3B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AETaplinx%20iOS%E3%81%AEappcrash%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169705%22%20target%3D%22_blank%22%3E%40ukcas%3C%2FA%3E%20-%20Taplinx%20iOS%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%80%8C%E6%9C%80%E6%96%B0%E3%80%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF2.0.0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%20%3CSPAN%3EapduExchange%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%8B%E3%82%89TL_TagAPDUResponse%E3%82%92%E8%BF%94%E3%81%99%E3%81%A8%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%8F%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81j2objc%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8B%E3%82%89%E3%81%AE%E7%94%9F%E3%81%AEIOSByteArray%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFtaplinx%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%ABC%23%E3%83%90%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AETaplinx%20iOS%E3%81%AEappcrash%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%8FTaplinx%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8B%E3%82%89%E6%9D%A5%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E-%20(null%20%E8%A8%B1%E5%AE%B9%20TL_TagAPDUResponse%20*)apduExchangeWithByteArray%3A(NSData%20*_Nonnull)apduData%3B%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%3A%3CBR%20%2F%3E-%20(null%20%E8%A8%B1%E5%AE%B9%20IOSByteArray*)apduExchangeWithByteArray%3A(IOSByteArray*_Nonnull)apduData%3B%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E3%81%8D%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AETaplinx%20iOS%E3%81%AEappcrash%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%80%E3%83%9F%E3%82%A2%E3%83%B3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%81TapLinx%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E5%88%B6%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-csharp%22%3E%3CCODE%20translate%3D%22no%22%3EMobileFacilityApp%5B5223%5D%20exceeded%20mem%20limit%3A%20InactiveHard%203072%20MB%20(fatal)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3ETapLinx%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(ApduExchange%E3%82%92%E4%B8%8A%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E4%BB%A3%E7%90%86%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%20APDUHandler%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-java%22%3E%3CCODE%20translate%3D%22no%22%3Elet%20reader%20%3D%20TL_IOSNFCReader(uid%3A%20tag.identifier%2C%20historicalBytes%3A%20tag.historicalBytes%20%3F%3F%20Data())%0A%0Ahandler%20%3D%20TapLinxApduHandler(reader%3A%20reader)%0A%0Ahandler.delegate%20%3D%20self%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%0AlibraryManager%3F.setApduHandlerWithApduHandler(handler)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%86%85%E3%81%AB%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-java%22%3E%3CCODE%20translate%3D%22no%22%3Efunc%20apduExchange(withByteArray%20apduData%3A%20Data)%20-%26gt%3B%20TL_TagAPDUResponse%3F%20%7B%0A%0A%20%20%20%20%20%20%20%20var%20tagAPDUResponse%3A%20TL_TagAPDUResponse%3F%0A%0A%20%20%20%20%20%20%20%0A%0A%20%20%20%20%20%20%20%20if%20connectedTag%20!%3D%20nil%20%7B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Send%20Tag%20Type%20Native%20of%20ISO%20and%20the%20apdu%20as%20NFCISO7816APDU%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20executeAPDUCommandOn7816Tag(tagType%3A%20tagtype%2C%20apdu%3A%20apdu)%20%7B%20data%20in%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20let%20appendedData%20%3D%20data%0A%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20tagAPDUResponse%20%3D%20TL_TagAPDUResponse(responseData%3A%20appendedData%2C%20tag%3A%20self.currentTag)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20semaphore.signal()%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20let%20_%20%3D%20semaphore.wait(timeout%3A%20.now()%20%2B%203.0)%0A%0A%20%20%20%20%20%20%20%20%7D%20else%20if%20connectedMifareTag%20!%3D%20nil%20%7B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20let%20semaphore%20%3D%20DispatchSemaphore(value%3A%200)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20print(%22MIFARE%20CAPDU%20%3CLI-EMOJI%20id%3D%22lia_mobile-phone%22%20title%3D%22%3Amobile_phone%3A%22%3E%3C%2FLI-EMOJI%3E-%26gt%3B%3CLI-EMOJI%20id%3D%22lia_credit-card%22%20title%3D%22%3Acredit_card%3A%22%3E%3C%2FLI-EMOJI%3E%20%5C(apduData.hex)%22)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20executeAPDUCommandOnMIFARETag(apdu%3A%20apduData)%20%7B%20data%20in%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20print(%22RAPDU%20%3CLI-EMOJI%20id%3D%22lia_mobile-phone%22%20title%3D%22%3Amobile_phone%3A%22%3E%3C%2FLI-EMOJI%3E%26lt%3B-%3CLI-EMOJI%20id%3D%22lia_credit-card%22%20title%3D%22%3Acredit_card%3A%22%3E%3C%2FLI-EMOJI%3E%20Data%3A%20%5C(data.hex)%22)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20tagAPDUResponse%20%3D%20TL_TagAPDUResponse(responseData%3A%20data%2C%20tag%3A%20self.currentTag)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20semaphore.signal()%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20let%20_%20%3D%20semaphore.wait(timeout%3A%20.now()%20%2B%203.0)%0A%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20print(%22Tag%20Response%20%5C(String(describing%3A%20tagAPDUResponse))%22)%0A%0A%20%20%20%20%20%20%20%20return%20tagAPDUResponse%0A%0A%20%20%20%20%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%8D%98%E7%B4%94%E5%8C%96%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ETapLinx%E3%83%81%E3%83%BC%E3%83%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AETaplinx%20iOS%E3%81%AEappcrash%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%80%81apduData%20%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%20NSData%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20IOSByteArray%20%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AETaplinx%20iOS%E3%81%AEappcrash%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%84%E3%82%89TapLinx-v2.0.0%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82TapLinxApduHandler.h%E3%81%AB%E3%81%AF%E3%80%81%E5%AE%A3%E8%A8%80%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E-%20(nullable%20TL_TagAPDUResponse%20*)apduExchangeWithByteArray%3A(NSData%20*_Nonnull)apduData%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%20IOSByteArray*%20%E3%82%92%E8%BF%94%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E5%89%8D%E8%BF%B0%E3%81%AE%E7%97%87%E7%8A%B6%E3%81%A7%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
