Hello gopesh,
Yes it supports. You can do it with following API:
- ISOReadBinary - command requires manual encryption and MAC-ing of payload. And also you need to select NDEF file upfront with ISOFileSelect
- ReadData (with CommMode.FULL) - recommended
byte[] readData(int fileNumber,
int offset,
int length,
MFPCard.CommunicationMode commMode,
byte readAccess,
byte readWriteAccess)
In both cases you need to perform mutual authentication first, as default Read Access Rights to Proprietary file are granted for Application Key nr. 2 (check datasheet of NTAG 424 DNA) only.
TapLinx team
