how to configure dtsec speed on T2080 RDB board
manishraturi
How to configure the speed of DTSEC 3 using UBOOT on T2080 RDb board
bpe
u-Boot always trusts PHY autonegotiation. There is no tool like linux ethool. You have to alter the driver and rebuild to achieve that.
One possible way I see is to set phydev->advertising to the desired values before calling phy_config() in init_phy() in drives/net/fm/eth.c
Platon
