What is ESEL in TLB ?
ソリューションへジャンプ
2,480件の閲覧回数
vinothkumars
Senior Contributor IV
Hi All,
I am doing u-boot debugging in T4160RDB target.
disable_tlb(14);
disable_tlb(15);
14 and 15 are ESEL (Entry Select) parameter.
What is entry select (ESEL) ?
How ESEL related with MMU TLB ?
VinothS
Vinothkumar Sekar
ラベル(3)
タグ(5)
2,249件の閲覧回数
herbert369
It is a part of the chip's memory-management unit. The TLB stores the recent translations of virtual memory to physical memory and can be called an address-translation cache shareit apk
5 返答(返信)
2,250件の閲覧回数
herbert369
2,249件の閲覧回数
ufedor
These are specific entries numbers in the selected TLB array.
2,249件の閲覧回数
ufedor
Please refer to the e6500 Core Reference Manual, Table 2-39. MAS0 field descriptions — MMU read/write and replacement control:
https://www.nxp.com/docs/en/reference-manual/E6500RM.pdf
2,249件の閲覧回数
vinothkumars
Will you please explain what is 14 and 15 for esel parameter.
VinothS
Vinothkumar Sekar
2,249件の閲覧回数
vinothkumars
Thank you for your reply.
VinothS
Vinothkumar Sekar
