[U-boot & Linux] Change location of the DDR SDRAM start adress in CPU Physical address range
Search instead for
yusufalti333
On T1042D4RDB-64B, Which variable(s) in U-boot side and DTS node in kernel side is responsible to locate DDR RAM in CPU physical memory map ?
ufedor
ufedor
