On T1042D4RDB-64B, Which variable(s) in U-boot side and DTS node in kernel side is responsible to locate DDR RAM in CPU physical memory map ?
Solved! Go to Solution.
CONFIG_SYS_DDR_SDRAM_BASE in the "T104xRDB.h":
u-boot/T104xRDB.h at b3f98d438eefd1b355efdec0b50af5813ff8d0e1 · qoriq-open-source/u-boot · GitHub
