In T4240 Voltage ID is fused. and VID range is from 0.9875V to 1.1V.
1. Want to confirm if it's different for different chip for same Order number ?
2. If yes, then can you please provide VID range for PT4240PSE7QZB ?
The VID value varies and is not fixed per chip marking. parts of any speed / power can have a VID fuse set to any of the allowable values. They are independent
