T2080QDS Memory may not work
crashbuzz
Hello NXP community,
I have powered my T2080 QDS board as usual and suddenly the U-Boot output was like in the screenshot below. Can anyone provide me with a solution on how to get rid of this error? Currently I am stuck at this point not knowing how to move on.
yipingwang
Hello crashbuzz,
First please make sure that you are using the original DDR provided in T2080QDS.
Please use the default clock(Core/Platform/DDR = 1800MHz/600MHz/1866MT/s) configuration on the target board.
Please configure your target board to the default switch settings.
TIC
crashbuzz
Hello yipingwang
thank you for the answer. Can you tell me which one is the "original DDR provided in T2080QDS". Maybe I have the wrong one.
