T2080 SRAM memory issue
3,670 次查看
VismaySharma
I am using T2080 RDB currently working on the boot of the same. While configuration we have defined SRAM LAW window as well as the SRAM initial configurations as mentioned in the attached screenshots. While testing what we have seen when using a stw command the contents aren'tcopied to the EA but the command executes with no output. When LD command was executed causes failure in previous assembly commands which still havent been executed. Can someone help me with the same.
Vismay
4 回复数
3,617 次查看
SebastianG
Hello @VismaySharma,
Could you please provide me a log with the values of DDR registers?
Sebastian
3,563 次查看
VismaySharma
Hi Sebastian
Any updates on the same?
Vismay
3,599 次查看
VismaySharma
Hi Sebastian
Please find below attached DDR configuration.
标记 (1)
3,651 次查看
SebastianG
I would like to inform you that I'm working on your questions, I will let you know as soon as I have an update.
Thank you so much for your patience
Sebastian
