the configuration is correct.
Selected "Auto configuration" and "Discrete DRAM"
Type = DDR3
DRAM speed Rating = 1600 MT/s
Output Data rate = 1600 MT/s
Rank/Chip select = 2
tCL = 11 clocks (13.8ns)
Data bus width = 64 bits
DRAM configuration per device = 8Gb: 512Mbx16 (the part is a dual-die chip, 512Mbx16 x 2 = 1Gx16)
user should properly configure the "Start Address" and "Size" for CS0 and CS1 respectively in QCVS.
The error “DDR initialization failed: D_INIT was not cleared by hardware” during QCVS validation typically means the DDR controller never completed its initialization sequence.
the possible causes include:
1. Clock or reset issues
DDR initialization requires stable clocks and proper reset sequencing. If SYSCLK or DDRCLK is unstable or incorrectly strapped, D_INIT will not clear.
Check that DIFF_SYSCLK and PLL ratios match T2080 datasheet requirements.
If DRAM device is held in reset or not properly released, D_INIT will never clear, check DRAM reset signal, user can refer to AN5097 as below:
JEDEC specifications for DDR3/3L/4 UDIMM or discrete DRAM require:
1. DRAM reset signal is asserted for a minimum of 200 μs 2. CKE signal is in logic level low for a minimum of 10 ns before the DRAM reset signal is deasserted 3. CKE signal remains low for a minimum of 500 μs after the DRAM reset signal is deasserted, Figure 18(see AN5097) illustrates these signal timing requirements.
2. Power Rail Sequencing
If DDR power rails or VDD_SOC are not within spec during initialization, the controller cannot complete training.
Ensure all voltages meet T2080 specs before DDR_RESET is released.
3. Incorrect DDR Configuration parameters in QCVS If timing parameters or memory topology settings do not match the DDR device’s datasheet, the controller cannot finish initialization.
