Hello!
We are using a T1042, and found a pin table on this forum to help create the part. However, it looks like the pinout provided has repeated pins based on each peripheral. Is there a version of this pinmux document that does not have the repeating pins for each peripheral, so we can plug into our schematic symbol generator?
Thank you for your help!
Hi Hector,
Thank you for the response. While the PDF is helpful, we are not able to easily import it into our tool to create the symbol without extracting that info manually from the PDF. Is there an excel sheet version of this information?
A. Kowalczyk
Hello @akowalczyk
Hope this post finds you well,
Unfortunately we do not have available such excel file,
Nevertheless can provide the symbol file for the device,
Please note that in order to provide such a file it is necessary to create a technical support ticket and mention that the new case is related to this one.
You can create a new ticket using the technical support web located in the following link:
Hector Villarruel
Hello @akowalczyk
The pinout list of the T1042 is located on pages 10-44 of QorIQ T1042, T1022 Data Sheet, Rev. 2, 06/2015.
Please find attached on this post the Data Sheet of the device.
BR,
Hector Villarruel Silvadoray
