I built "fsl-image-full" with SDK1.8 and successfully booted the board(T1024RDB) but when I enter "ifconfig" command I can see only "lo" interface. How to enable ethernet interfaces?
Thanks and Regards,
Veeru
Use command “ifconfig –a”command for viewing the configuration of all interfaces.
To enable an inactive interface, provide ifconfig with the interface name followed by the keyword up.
See the following page:
http://www.computerhope.com/unix/uifconfi.htm
Pavel
