T1024 pin list
T1024 pin list
1,470 次查看
PaulWalker
Is there a pin list sheet or spreadsheet for the T1024? Extracting a large table from the datasheet PDF is somewhat tricky and error prone. A separate sheet would help greatly.
1,452 次查看
Hector_Villarruel
Hello @PaulWalker
Hope this post finds you well,
In order to provide the requested information, please create a new ticket using the technical support web located in the following link:
https://support.nxp.com/s/
I would also recommend you that in order to follow this request, please do not forget to mention on the case description this case number which is: # 00548617
Hector Villarruel
1,453 次查看
Hector_Villarruel
Hello @PaulWalker
Hector Villarruel
1,433 次查看
PaulWalker
Hi, Thanks. Support case is 00549077
