T1024 IFC GPCM minimum timings
888 次查看
PaulWalker
The reference manual T1024RM gives non-zero minimum values for some GPCM fields: TACSE, TEAHC and TRHZ.
My device does not expect or need these extra time gaps. Also the extended hold time (TRHZ) is not needed.
How do I remove these extra times?
1 回复
838 次查看
Oswalag
You can only set the minimum values available in their respective registers, this is fixed behavior - i.e. no possibility to reduce the delay.
