I am working on T4240RDB-64B. I faced NAND is not detecting in u-boot (flash id itself wrong) but in Linux, NAND is detecting.
NAND chip is Micron MT29F8G08ABABAWP
Configuration according Hardware, Please check the attached header file (T4240RDB.h) for NAND configuration.
Chip Select 1 - NAND
And also I attached the log (Log file_20191031_1210.txt) for your reference. If anyone experience, Please response.
VinothS,
Please provide photos of the on-PCB markings and stickers to determine the RDB board revision.
Ufedor,
I apologize for the inconvenience , I don't have any board as well as design as you expected. I give only software support from last 6 months.
Thanks & Regards,
VinothS.
To provide software support it is required to understand which exactly board is used first.
There is no word about the RDB board in the provided document.
Hi Ufedor,
Our board is T4160RDB
CPLD is current bank and board revision is 0
VinothS
I'm not aware about such board from NXP.
Please provide photos of the on-PCB markings and stickers to determine exact board revision.
Thank you Ufedor,
I am not sure, I will get or not from Customer. But, I will try my level best. I apologize for the inconvenience.
VinothS,
