Is there an error in the QorIQ SDK 2.0 documentation?
1,435 次查看
matthewrendell
I am using QorIQ SDK 2.0 and there appears to be an error in QORIQSDK21611 Rev. 0 (QorIQ SDK v2.0-1611 Documentation) for the T1040D4RDB. In table 92 the 'Linux.uImage (alt bank)' location is defined as 0xEE020000, I'm pretty sure it's supposed to be 0xEC020000, can anyone confirm please?
Mat.
标记 (2)
1,349 次查看
ufedor
You are right.
The 0xEE020000 is a typo - should be 0xEC020000.
1,350 次查看
ufedor
You are right.
