Interrupt Response Delay During IFC Access on T1024
hankjeon
I am using a T1024 processor, with an external interrupt signal (IRQ0) as the RTOS tick, and the IFC for accessing an I/O board. However, when performing continuous write operations on the I/O board, I observe a delay in the interrupt response. Specifically, the interrupt signal is activated, but the ISR is called approximately IFC 10-cycles later.
Could you please advise on potential causes for this delay and suggest ways to mitigate this issue?
Tags (3)
Bio_TICFSL
You will have to check the RTOS, because the T1024 still work normal.
hankjeon
I'm wondering if there's a way to set priorities between accessing IFC and interrupts.
