How to determine what DDR4 memory is installed - T1040
796 次查看
daveclark
My project buys in a processor/memory module for integration into our product.  The supplier has had to change the memory part due to obsolescence, this will require a code update to configure the memory correctly.  The problem comes with there now having to be two different variations of software released.  My question is, is there a method for determining what DDR4 memory is attached to the processor programmatically?  We are using T1040 processor.
Thanks in advance,
Dave
1 回复
755 次查看
ufedor
For discrete SDRAM devices - no.
