How to compile the kernel separately for T2080
2,283 次查看
hongyuanzhao
How to download the cross-compilation tool ..?
2,269 次查看
yipingwang
Please download the ISO Image: QorIQ Linux SDK v2.0 PPC64E6500 IMAGE(QorIQ-SDK-V2.0-PPC64E6500-IMAGE-20160527-yocto.iso).
from https://www.nxp.com/design/design-center/software/embedded-software/linux-software-and-development-t...
You will find fsl-toolchain folder in this ISO, please run the following command to install the toolchain in /opt/fsl-qoriq/2.0.
./fsl-toolchain/fsl-qoriq-glibc-x86_64-ppc64e6500-toolchain-2.0.sh
source /opt/fsl-qoriq/2.0/environment-setup-ppc64e6500-fsl-linux
6 回复数
2,264 次查看
hongyuanzhao
got it ,thanks I will try.
2,270 次查看
yipingwang
2,247 次查看
hongyuanzhao
linux$ powerpc64-fsl-linux-gcc test.c
test.c:1:19: fatal error: stdio.h: No such file or directory
#include <stdio.h>
compilation terminated.
2,245 次查看
hongyuanzhao
Cross compilation tool cannot be used
2,127 次查看
yipingwang
$ source /opt/fsl-qoriq/2.0/environment-setup-ppc64e6500-fsl-linux
$ ${CC} test.c -o test
2,112 次查看
hongyuanzhao
Thank you very much, Yiping.
How to compile the kernel ..?
%3CLINGO-SUB%20id%3D%22lingo-sub-1880372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E4%B8%BAT2080%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%B8%8B%E8%BD%BD%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%B7%A5%E5%85%B7..%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1885140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E4%B8%BA%20T2080%20%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1885140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%E4%B8%80%E5%B9%B3%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8..%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1882551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E4%B8%BA%20T2080%20%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1882551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%B7%A5%E5%85%B7%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E4%B8%BA%20T2080%20%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
