How to build ppc32 firmware image for T1024RDB using LSDK?
1,442 次查看
kenjitakahashi
I use a custom board based on T1024RDB. Can I create a 32-bit image (u-boot, kernel, rootfs, etc) with LSDK 19.09?
I ran the following command on Ubuntu 18.04, but only flex-installer was created in ./build/image.
$ flex-builder -m t1024rdb -a ppc32
标记 (3)
1,312 次查看
alexander_yakov
For T1024RDB board we offer "Linux SDK for QorIQ processors".
This is said at T1024RDB board Product page:
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/run-control-d...
Direct link to Linux SDK for QorIQ processors Product page:
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/linux-sdk...
LSDK does not support T1024, please look the following LSDK User Guide, Section 3.4 "Supported Targets":
https://www.nxp.com/docs/en/user-guide/LSDKUG_Rev19.09_311219.pdf
1,313 次查看
alexander_yakov
1,312 次查看
kenjitakahashi
Thank you for your reply.
I wanted to use LSDK because Yocto Jethro (QorIQ-SDK) and linux-4.1 are EOL, but if it doesn't support it, it can't be helped...
Kenji
